12-05-2022 02:32 PM
I currently have three different phone numbers with PM but when I log in I only see the one. What do I have to do to see the other numbers associated with my account?
12-05-2022 03:00 PM
If you're only seeing the same phone number everytime you login to your account, your probably looking at cached information from the last time you logged in.
Try logging into your account using a browser in incognito or private mode, when logging into each of your accounts associated to each phone number.
12-05-2022 02:57 PM
Each account has only one phone number. You have to create 4 self-serving accounts (4 unique emails) and to log in into each account separately.
12-05-2022 02:37 PM
HI @RounderP51
Yes, your one email login can only see one account. Each account needs a unique email.
Do you recall setting them up? Some people use email aliases for the other account.
You can try using Reset Password and enter your other emails and reset the password that way
If you cannot find it, then please open ticket with CS agent and they can help
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
12-05-2022 02:35 PM
@RounderP51 hi each phone number needs it's own email/account if this is not the case
you need the help of a service rep to fix things for you
There are two ways to contact a customer service agent , open a ticket through Simon here https://publicmobile.ca
Or private message them here
https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user
12-05-2022 02:34 PM
@RounderP51 PM is one email needed for one account/phone number. You have 3 different phone numbers, then you will need to have 3 email addresses used to setup 3 accounts
Not sure if you did setup the other two. If not, or if you forgotten, please open ticket with PM Support and they can sort this out for you
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
12-05-2022 02:34 PM
Each number is associated with a separate account and therefore a separate email. Try your other email accounts and use the Forgot your password link if you need to.
