Phone Error
garbage_in
My phone advises that I have an "Internal Serer Error".  How do I address it?
CountyDownIeUk
@garbage_in Please Mr. Error.......
@garbage_in
Usually this shows up when you try to login to your account on a computer or phone.
The Self Serve account is under maintenance overnight and should be up soon
darlicious
@garbage_in
Do you have any plan data remaining in your account?
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here   ....for additional member supplied info.
Dunkman
@garbage_in
More details would be helpful.  What specifically is happening when you see this error?  Using data to search/visit a website?
A quick google search:
https://askleo.com/whats_an_internal_server_error_and_how_do_i_fix_it/
HALIMACS
@garbage_in
Has this just developed?  ( working before??)
Worst case, reset/restore to factory.
@garbage_in   Did you try reboot the phone?
Also, it works when you make voice calls or you can receive incoming calls with it?  Just having problem with mobile data? you sure you have Mobile Data enabled on the phone?
