06-22-2021 08:37 AM - edited 01-06-2022 02:55 AM
My wife has a LG flip-top phone and keeps receiving the message displayed in the .jpg message. The message is received up to 10 times a day .... very frustrating and annoying.
Is there a way to block or trace this call? I have traced the phone number shown in the image, but the results were "unknown or does not exist"
06-23-2021 08:17 AM
06-22-2021 12:31 PM
@Demas11 : Be aware that using the internet or wifi sites could be compromised with the old Z10.
You might also want to either blank out those red numbers or remove that image and from your image library. How's life in Leduc? 🙂
06-22-2021 12:17 PM
Greetings all ....
I have a Blackberry Z10 that I will probably setup for Julie .... she really likes the LG flip top ,,,, but times are changing and she will have to learn something new and different 😂 .
Thanks to all for your tips, tricks and suggestions, I really appreciate the input.
Demas11
06-22-2021 10:02 AM
Or buy a older model smartphone.....iPhone 4S or 5S.
06-22-2021 09:41 AM
If the guides from Tracphone don't work then you can try to do it thru the security features.
Not ideal but could be employed long enough for them to stop sending the texts. You could set up voicemail for legitimate callers not on the list to leave a message.
06-22-2021 09:24 AM
Scam shipping notification...
https://800notes.com/Phone.aspx/1-437-788-5986
try blocking the number on your phone as by others above.
06-22-2021 09:24 AM
Just downloaded the phone's manual, but no mention on how to block numbers.
Here is a another link:
https://tracfoneusermanual.net/block-calls-lg-classic-flip-phone/
Might work for that model.
06-22-2021 09:23 AM
I used to have that model of flip phone! I knew it looked familiar.... let's see what I can find on that model.
06-22-2021 09:18 AM
800Notes will give you information about this number.
See Here https://800notes.com/Phone.aspx/1-437-788-5986
Likely a VOIP number that has a fake caller ID. It is very easy to do.
06-22-2021 09:10 AM
Hi and thanks for the quick reply .... Julies' phone model is an LG-A341 .
Demas11
06-22-2021 09:04 AM
Try this...
Here’s how to block a number on a Tracfone flip phone like LG Classic Flip:
06-22-2021 09:02 AM
No way to block the text from Public mobile end.
Usually, can block phone number from your phone. From your screenshot, there looks like an options tab. Click on options to see whether there is an option to block that specific number. Or check the user manual on your wife's phone to determine whether that specific phone has that function.
06-22-2021 08:58 AM
That's a tough one. What is the exact model of her flip phone. Since generally you cannot block numbers on a flip phone some do have access to a white list which works in a similar way.
