Permanent ban
Rdes
Hi I was just curious if there was anyway to permanently banning a number from calling or me calling them through the provider. Since blocking doesn't seem to help me much.
Thanks
Grinch
Why doesn’t blocking work for you?
If an iPhone you can use Focus, Do Not Disturb and specify a phone number so your phone won’t ring BUT will show as a recent and allow voicemail. You can also make a contact for any like like “Don't Answer Obnoxious Salesperson” with the number you don’t want to hear from and you give it a specific ring notification.
0
Chalupa_Batman
Thanks
Sadly Public Mobile is a basic service that offers very little bells and whiles. Even though Call Control offered by Telus to their customers should be mandatory for all their services.
For now, look into TrueCaller app for Android or iPhone.
Here are ANDROID APPS and here are iPHONE APPS
Hope this helps.
hi @Rdes
Sorry not with PM.  there is no network level ban here.  I am not sure if other carriers provide that either
you probably know  if you do a device level ban, the calls will still go to the voicemail and that is the best you can do
