09-30-2022 03:04 PM
Hi everyone my gf set up my sim card and she forgot what info and password to the sim so I can't even change the pin now that I added $20 to my account how do I apply it without having to provide the pin ?!
Service
09-30-2022 03:37 PM
Hi @Alikatt80
if you use a voucher by calling *611, you don't need a PIN
Is the plan $15? if it is, it will be enough to reactivate. If you loaded the voucher, wait 10 mins, reboot the phone and see if the system reactivated the account
09-30-2022 03:31 PM
With a voucher and it never got applied to account because I missed the renewal day
09-30-2022 03:10 PM - edited 09-30-2022 03:11 PM
@Alikatt80 You added the $20 voucher by dialing 611? If that covers the plan cost+tax then your plan should be activated as you don't need a PIN to add voucher to your account. edit: perhaps try rebooting the phone too.
For email change and password reset, you need to submit a ticket via chatbot here: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
If unable to submit a ticket, then send a private message to CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
09-30-2022 03:08 PM
Is she not able to look in all her emails to find a welcome email from when the account got activated?
How did you add $20? Voucher? Through 611?
Did she activate your account in a store?
