Payment
Engel
I need  to make a payment to my account but in order to do so I have to type in the CODE that is sent to my EMAIL.  Here is the problem it does not give me time to check the email on my COMPUTER  (I don't have email on my phone) then go back and  type in the code sent.  Time expires, and I'm back to square one, can't get into my account.
 What happened to the option of receiving the code VIA SMS to my phone?   This was NO PROBLEM.   Email is a big problem for me, time expires. Is there a way to receive the CODE VIA SMS?
Why are you making it more difficult to LOG IN to make payments?  It used to be so easy without this CODE verification.
8 REPLIES 8
Engel
Thank you very much....all good now
dust2dust
And vouchers can be bought in lots of stores and a couple places online. There's also the real time payment method in a few stores.
@Engel
you also have the option of loading funds to your acct by dialing 611 from your phone.
If using credit card, you'll need your 4 digit PM pin number.
If paying with vouchers...no PM pin req'd.
Engel
Thank you, It seems I am late making payment.  Payment requests  seem to change frequently now. Plus I used to get notification when my payment was due, that is gone now.  So what should I do now?
Yes, the SMS option is not there now.
hycm53
@Engel I'm not sure why you don't have time on your computer to check your email that sent 2FA? I always get 2FA send by email.
H @Engel   you ever login to My Account with this email before? Maybe the email address on My Account was wrong?
If you still cannot get the code and unable to login , Please submit ticket to PM CS agent at : https://publicmobile.ca/chatbot.
First type Forgot Login,
hycm53
When login there're two choices to choose, send 2FA by SMS or by email. If you only have one email choice to chose then it means your account is suspended that's what I understand.
Meanwhile you can set your email app to get email.
@Engel   the count down time you see on the login page after you click 2FA code is a time before you can request another 2FA code.  It is not a time you can use the code.  You can use the code a lot longer than that time
So, try again,  check email and enter the code.  (When you check email, keep refresh the page or your email client as some are set to automatically check only ever 15 mins or so.  Manural refresh to get the code quicker)
With the option to send to the phone, it will not be available if your phone's account is expired.
