Payment
06-14-2022 03:01 PM
I have been using my TD visa debit card for all my auto pay. Had to update new card. Now saying won't take it
Payment
06-15-2022 03:41 AM
exactly I agree, I just did this yesterday, it wouldn't accept my new card until I removed the old car
06-14-2022 08:17 PM
Hi @Noni2 It actually better NOT to remove the card but just go straight to Replace card.
What error you got? you can try it just once more (not more than that, you can trigger fraud lock)
If still fails, open ticket with PM CS Agent and have them to add the new card for you.
At : https://publicmobile.ca/chatbot.
Follow this to get to ticket open screen quicker:
- start by typing : Contact CS Agent
- then Click "Contact Us"
- then Click "Other"
- finally Click "Click here to submit a ticket"
06-14-2022 08:14 PM
Did that still doesn't work
06-14-2022 04:08 PM
@Noni2 wrote:Did that. So Visa debit is ok
@Noni2 So you were able to replace the Visa Debit card by using Remove option as suggested by @RossN ?
Just to add if you did Remove and replace the payment card, make sure to enable autopay again, as Removing the card will also remove autopay unlike replacing a payment card.
06-14-2022 03:50 PM
06-14-2022 03:19 PM
@Noni2 `hi when you go into your self serve in manage my card click on remove this card not replace this card then start new 😀
06-14-2022 03:06 PM
HI @Noni2 Maybe just Autopay failure. it happens some time
Go back to the Payment page and make a manual one time payment using the option "Other .." and enter the amount you want pay
If payment made successfully, then just logoff My Account . Wait 5 mins , reboot the phone.
You can log back into My Account and see if status show Active again
06-14-2022 03:05 PM
