01-31-2022 02:02 PM
01-31-2022 11:50 PM
@Sunnymeowc wrote:after how many days you put the balance in your public mobile plan if it more then 90 days you didnot use that one it means its gone and number gone be reissue to someone else soon
In this situation, that didn't happen. The customers wouldn't have been able to add the funds from the voucher to a closed account.
01-31-2022 06:07 PM
I would suggest you try again in an hour online or call 611.
01-31-2022 05:44 PM
If you have no working service and your account is suspended ensure that the amount in your available funds is equal to or exceeds your plan amount. If it does not you need to add the extra funds so it does. Your account should then automatically reactivate. If it does not then go to the plans or usage page and click on lost/stolen. Suspend your account. Log out/in. Resume your service. Your plan will automatically reactivate. Log out and reboot if necessary.
FYI....loading your pm voucher via 611 will automatically reactivate your service as long as your payment equals or exceeds your plan amount and as long as your account is not suspended via lost/stolen.
01-31-2022 04:14 PM
01-31-2022 03:11 PM
01-31-2022 02:08 PM - edited 01-31-2022 02:39 PM
@sPat80 did you see the amount you loaded from the voucher showing as "Available Fund" on My Account?
If so, check to see if you see a button "Reactivate current plan" around , if so, click on it , then logoff My Account and reboot your phone
Once your phone comes back, see if it works
If still fails, Log back onto My Account, Go to the plans or usage page and click Lost/Stolen to Suspend the service.
Log off from My Account and then Wait 5 minsutes
Log back in My Account. Resume the service. The plan should automatically reactivate as you already have enough funds in the system to pay for the renewal.
