Payment voucher not activating
robfeehan
Won't let me add a voucher
14 REPLIES 14
@robfeehan   was the issue resolved your?  did you open a ticket with PM?
another customer with the same issue got this resolved by CS Agent.  They have manually apply the voucher on behalf.  Hope you have yours resolved as well.
@robfeehan
* some vouchers take 24 hours to activate,
you can call 1 855 4PUBLIC and add your voucher PIN
or call *611
close all Browser and do clear cache and cookies for any Browser,
and try open one Browser incognito mode,
You will usually find it at the top or bottom of the receipt. To top up your account with a voucher, log into your  Self-Serve, account, click on the "Payment" tab, then "One-time payment". In the form that appears on the next page, click on "Payment voucher" as the payment method, enter the voucher code below, then click "Submit".
if you can't fix it you need to Contact Customer Support Agent by CS_Agentand Explain your issue to
they can solve your issue, they are nice service Team the will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent,and Submit a Ticket,
Spoiler
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to Customer Support Agent by CS_Agent,Click Here link,to get started. Type,, Ticket ,, Click ,, Contact Us ,, Select your issue ,,
    Click here to submit a ticket↗↗.
  • or you can send a private message to Customer Support Agent by CS_Agent, by Click Here link,
  • phone number,
  • account 4 digit pin,
  • Email address,
  • Customer Support Agent by CS_Agent, will Response to your inbox by private message
  • During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
    • Monday to Sunday: 6 AM to 10 PM EST
    • Note: For public mobile No Support by phone call or Email.. only by CS_Agentprivate message..
         Good Luck..
 @robfeehan : And when you call 611 what does the recording give you for a balance?
Edit: you said you couldn't log in...why? Did you create an account? Did you try Forget your password?
thanks @Dunkman ..keep us posted
@robfeehan   PM is all online support.  Open a ticket and have them look into it.  there seems to be higher number of voucher related issues.
To open tickets:
1. For faster response (2-48 hours), Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
Start with typing "Submit a ticket", click "Contact Us", click "Other" from the choices, click "Click here to submit a ticket". Then follow to complete the ticket submission.
2. Or you can Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
**Monitor your Community inbox, envelope on the top right, after ticket is opened.  CS Agent will reply and work with you  via messaging there
@softech wrote:
..quiet some number of vocuher related threads since yesterday.. at least the 5th one that I saw.  Maybe issue on the backend?
@softech
I was thinking the same thing.  About 5-6 threads in the past 1-2 days with similar issue. I will try to let PM staff know, but it is the weekend though.....
robfeehan
Walmart and I've done this multiple times with no problem and of course I can't sign in online and there is no number to contact anyone
 @robfeehan : Where did you get the voucher from? Are you sure you're using the right 12 digit PIN?
@robfeehan
May be time to contact Public Mobile support.
  1. Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select contact Customer Support Agent, then select other (or the topic that more closely matches your request).  Click the result which states Click here to submit a ticket and follow the prompts,  or,
  2. Send a private message to the Customer Support Agent by clicking here  You’ll need to be logged into your Community account for the link to work.
robfeehan
Tried everything nothing will work
It shouldn't @robfeehan
Try clearing cache and cookies, then opening incognito mode.
Could also try using the pin number or the voucher number.
Some have both,  and some have reported using one or the other on either 611 or self serve with varied results.
robfeehan
Neither will work. I've never had one take 24 hrs before
HALIMACS
@robfeehan
Some take 24 hours to load.
Try both *611 and self serve.
Make sure you're using the PIN number on the voucher.
