Payment using balance loaded by vouchers and points
notchman1
Under the current points system you earn 5% back for every dollar spent.
If you load your account with vouchers do you get 5% in points back?
If yes do you get the points when loading voucher or when amount is deducted from balance?
sarah3339
Hello, @notchman1 , good question
it appears that no matter what way you choose to load your account, you will receive the 5% back in points. Don't stress you should see the rewards coming!
You should see the rewards coming your way when the amount is deducted (paid) form your balance.
@notchman1
Any type of payment will give you your 5%…CC, debit or vouchers when it is deducted from your account for the Top-up payment.
HI @notchman1
yes, loading vouchers is same as credit card, you will earn 5%.
