10-26-2015 10:30 AM - edited 01-04-2022 02:05 PM
Hey,
I just made a payment of 45.00 through self-serve.
It shows in my payment history, but the available funds still shows 0.00.
Thus, I can't change my plan.
Please help
10-26-2015 11:49 AM
10-26-2015 11:45 AM
It's 45.00 after taxes. In all I paid 50.85 (45 + tax)
So ideally I should get 45 to use to select my plan.
However, currently, it shows 0.00 as available funds 😞
10-26-2015 11:41 AM
Hi @issuetree, not sure if your $45 include tax, or the addon plus tax is less than $45.
10-26-2015 11:34 AM
Thank you for the replies.
My account expired a few days back.
So I made the payment of 45.00 through my credit card. Now I want to use these funds to select my plan.
However, when I go to "Plans and Add-ons" and change plan, it says that I do not have the sufficient funds in my balance.
But when I check the "transactions" tab, it shows that I have made the payment today.
10-26-2015 11:29 AM
if you have a plan of $45 and you add $45.. the system will deduct the $45 you just added leaving you with $0. you would then need to add funds to change the plan..
Also I suggest adding money and then changing the plan just before your next renewal, as to not waste the money you just spent.
10-26-2015 10:39 AM
Hi @issuetree,
I'm not sure I fully understand your issue.
If you paid for a 45$ plan, it's normal that the balance of your account is now lower than the actual plan cost :
EX if you had 45$ in your account and paiy for a 45$ plan, then there's 0 left in your account.
The main question is : Can you currently use your 45$ plan with your SIM card?
