11-12-2022
02:37 PM
11-12-2022
02:46 PM
Dunkman
I made a payment to account xxxxxxx 604 xxx-xxxx
by voucher NO.5354xxxxxxxxx on NOV. 10, 2022 IN THE AMOUNT
OF $25.00 .
THIS AMOUNT WAS NOT CREDITED NOR APPLIED TO THE ACCOUNT.
THE BALANCE ONLY SHOWS $2.00
EXPLAIN WHY THIS ERROR HAS OCCURRED AND CORRECT IT.
Thank you
Melvs
Edit by Dunkman: removed personal information
11-23-2022 01:35 PM
The CSA agent Andu corrected the system failure and restored my account with the voucher payment.
Melvs
11-22-2022 04:38 PM
@Melvs Still stuck on this issue? Is it possible your account renewed just after adding the voucher? If so, it would have been used to pay for your plan. That $2 balance would then be the balance remaining after renewal.
11-12-2022 03:29 PM
@Melvs First use the down arrow top right of your post and select edit and then delete your email/phone # from it as you're posting on an open forum.
You maybe viewing a cached page so try logging into your self serve using incognito/private mode or another browser.
Also did your account renew today and do you have phone service?
11-12-2022 03:27 PM - edited 11-12-2022 03:29 PM
@Melvs this is an open forum, for your own protection, please remove your personal info (email, phone #). Go back to the post, click the down arrow and select Edit Message
for your payment issue, it could be that you are reading cached page. Try to login using Incognito mode and see if Payment History shows your last topup. Also check if the Available Fund is correct
If it still not showing correctly, open ticket with PM support
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
11-12-2022
03:25 PM
11-12-2022
03:41 PM
Dunkman
AGENT PLEASE
I made a payment to account x 604 xxxx-xxxx
OF $25.00 .
Thank you
Melvs
11-12-2022 03:10 PM
11-12-2022 03:05 PM
JK8
I USED 611 It states that the payment voucher has already been used.
PLEASE CORRECT THIS FOR ME. and REPLY TO ME THE BALANCE IN THE ACCOUNT AFTER PAYMENT WAS MADE ON NOV. 10
Thank you
Melvs
11-12-2022 02:58 PM - edited 11-12-2022 03:01 PM
@Melvs wrote:BROWSER CACHE IS CLEARED INGOGNITO USED
CORRECT THIS ACCOUNT FOR THE $25.00 P-AYMENT THAT WAS APPLIED TO THE ACCOUNT NOW
Melvs
@Melvs EASY ON THE ALL CAPS AND THE DEMANDS TO CORRECT THIS NOW! WE ARE ALL CUSTOMERS JUST LIKE YOU! YOU NEED TO OPEN A TICKET IF YOU THINK THE VOUCHER WAS ENTERED CORRECTLY AND IS NOT REFLECTED ON YOUR ACCOUNT.
YOU CAN CONTACT A CUTOMER SERVICE REP ONE OF TWO WAYS!
1. At https://publicmobile.ca/chatbot.
2. IF YOU HAVE TROUBLE WITH THE CHAT BOT: PRIVATE MESSAGE A CS AGENT AT:
IN EITHER CASE YOU SHOULD RECEIVE A REPLY WITHIN 48 HOURS THOUGH THEY ARE TYPICALLY FASTER! KEEP AN EYE ON THE ENVELOPE ICON FOR REPLIES!
11-12-2022 02:58 PM
What does Payment History say? Click on spinner icon to refresh.
Is the $2 in Available Funds from before? If so try adding voucher via 611.
11-12-2022 02:50 PM
Melvs
11-12-2022 02:50 PM
Go into your MY ACCOUNT....what does your transactions tell you?
11-12-2022 02:40 PM
Clear your browser cache and use incognito/private mode for self service. You might be looking at a cached version.
11-12-2022 02:39 PM
Click the arrow icon in top right corner of your post and remove personal information. This is a public forum and everyone can see all your personal info.
