03-23-2019 10:48 PM - edited 01-05-2022 06:58 AM
Hi,
Now that there is no longer a call centrer, it seems like I'm not able to pay my service. I tried to go on my self-serve account but I forget my password, but when i try to reset it this is what I see: ForgotPassword/OldPasswordNotValidContactAdmin. Resulting in me not being able to enter my account, therefore,unable to pay my phone. I would like to know what I should do to resolve this problem.
Thank you in advance
03-23-2019 11:36 PM
Yes you are right... So from previous messages it seemed like *611 was still working so I gave it another try and it worked.
Thank you for your answers everybody !
03-23-2019 11:30 PM
thank you very much @sunflowershine you made everything clearer!
03-23-2019 11:28 PM - edited 03-23-2019 11:29 PM
Using the 611 or *611 makes no difference. You get to the same place.
Is it that you had a credit card registered on file and you had been using that in 611 all this time? (seeing as how you didn't know what a voucher was)
Or did you used to call in and manually give your credit card number to them?
Is your service working?
03-23-2019 11:21 PM
@JeanCT wrote:Thank you for your answer, but what is voucher and moderator_team ? Also, I tried paying using 611 like I always do but it didnt work.
@JeanCT Voucher is what you buy from a store such as London Drugs or Walmart. The voucher has a set of code you need to enter to the system as money in your account. However, someone mentioned that they bought the voucher but they had to wait a few days to get the payment went through. It may not be a good choice. It will be cheaper if you set up as an auto pay by using credit card because you will have $2 reward given every cycle when your account is still active.
For private message to the Moderator, you can click on the icon with the "envelop" and send to "Moderator_Team". They will reply to your message within 2 days.
You must call *611, not just 611. "*" is needed.
Hope that helps!
03-23-2019 11:10 PM
Voucher = a code associated with a value to add in to your available funds
moderator_team = the employees of Public Mobile that can help with deeper account issues.
03-23-2019 11:05 PM
03-23-2019 10:50 PM
@JeanCT wrote:Hi,
You can buy voucher from store or recharge.com. Use *611 to add to your account.
If password reset doesn't work, you need moderator_team to help.
