06-13-2023 01:07 PM
I left Canada for summer vacation, and my acc is set to auto-pay. My you kindly help me pause my account and save my number? I’ve Ben using that acc for more than 3 years, it’s really important for me, it connected to all my other accounts in Canada. Thank you!
06-13-2023 03:26 PM - edited 06-13-2023 03:27 PM
@BKNS27 wrote:You can call 1-855-4PUBLIC from where you are. This is a toll free number but you maybe charged for LD. Use your security PIN to access your account then enter your number and follow the prompts to pause AutoPay.
There are never long distance charges for calling a toll-free number. No long distance charges is the defintition of toll-free. Callling the number will either work or won't.
06-13-2023 02:03 PM - edited 06-13-2023 02:07 PM
06-13-2023 01:18 PM
Hi @isvivvii if you are unable to login now from the code, click Resend code and they will give you option to send to email
if no choices for that, please submit a ticket with CS agent:
06-13-2023 01:17 PM
HI @isvivvii you have no service outside of Canada anyway (unless you are in US and pay for the roaming)
So, make sure those code you need to receive , change to email as a backup while you are away
06-13-2023 01:17 PM
The problem is it needs to receive a text msg to login, but I’m outside Canada. I’m unable to log in at the first place
06-13-2023 01:16 PM - edited 06-13-2023 01:17 PM
@isvivvii Hit resend a few times and see if you don’t get option for email code to send . If that doesn’t work try putting in the wrong code several times to hopefully get option for email
06-13-2023 01:15 PM
06-13-2023 01:15 PM
HI@isvivvii Yes, you can. Make sure you know you have 90 days to suspend or you will loss your account
Just go to My Account, Payment, then Manage Subscription and then disable "Subscribed". PM will not renew your plan at the end of this cycle. Remember when is the end of the cycle, add 90 days to it and that is the last day you need to come back and make a payment to resume the service. But don't do it on the 90th day, My Account always on and off. Try to do it couple days before
06-13-2023 01:10 PM
You can toggle off the subscribed setting in your account. Then on the next renewal it won't renew (assuming you don't have a balance). Now you have an important count down. You have 90 days of this grace to renew the account or you lose it all. Be sure to pay again maybe around day 85 in case of any possible trouble.
06-13-2023 01:09 PM
@isvivvii Log into your account and do this yourself like this
Turn auto pay OFF/ON 3 easy clicks
Or if you know the 4 digit PIN number
*611
