02-10-2023 01:17 PM
I paid my phone bill and that was on Sunday February 5 and still have no service HELP!!!
02-10-2023 01:51 PM
02-10-2023 01:49 PM
@Arden2 wrote:Ok but I can’t because I have to give the money to my boyfriend because he put it on his credit card. So I’m screwed is what I’m getting
Did you see the actual charge on your boyfriend's credit card in his transactions @Arden2 ?
It seems the transaction was unsuccessful. Or, as what was mentioned payment was sent to another account.
02-10-2023 01:46 PM
Well @Arden2 … Either that or your boyfriend screwed you with respect to this payment.
I’d be making sure it was applied to your account before repaying him - but that’s just me.
Before logging into your self serve account to check again, make sure to go incognito or private tab. Then when you’re on the self serve landing page, click those little refresher icons.
Then go onto your payment tab and see if the payment was, in fact, made to your account.
02-10-2023 01:43 PM
It says it suspended and hangs up on me
02-10-2023 01:42 PM
02-10-2023 01:39 PM
What recording do you get when you dial 611? You should be able to hear a balance and a due date or that it's suspended and your balance and it wants money.
02-10-2023 01:39 PM - edited 02-10-2023 01:39 PM
Consider purchasing a payment voucher and apply it to your account by calling 611 from the device or on self serve.
they are available at many drugstores, Walmart, gas stations, etc. etc.
some places refer to them as top up vouchers or top off cards for prepaid phone plans
02-10-2023 01:38 PM
But I’ve made the payment
02-10-2023 01:37 PM
It says to make a payment
02-10-2023 01:35 PM
So if the payment is showing as charge to his credit card, but not added to your account, then it must have gone on another account.
Does he have service with public mobile with that card registered?
It likely went on his account if if so, @Arden2
02-10-2023 01:34 PM
Yes on his credit it was taken but there’s nothing in my account nothing in the history or balance
02-10-2023 01:30 PM
I did all that just now and still saying it suspended
02-10-2023 01:29 PM - edited 02-10-2023 01:32 PM
You “sent” the money @Arden2 ?
Where did you send it?
When you view his credit card transactions, is there an amount charged that is equal or greater than your plan amount?
Also when you check your payment history in your self serve account, is it showing there or is it displaying under your available funds?
If it’s under your available funds, you should be able to just tap resume or reactivate button and be good to go.
You may need to reboot your phone.
02-10-2023 01:28 PM
02-10-2023 01:24 PM
No it saying suspend and I did send the money with my boyfriend credit card
02-10-2023 01:22 PM
@Arden2 wrote:What about the 45.20 that I’ve already sent because that was the last of my money
@Arden2 - we are customers and members like you here in the forum, and have no access to your account.
Is your account status ACTIVE?
Does is show any available balance owing in your My Account?
If your account is ACTIVE, try:
https://www.telus.com/en/on/outages
02-10-2023 01:21 PM
@Arden2 Check account it maybe sitting there in avaliable funds and make payment and reactivate
02-10-2023 01:21 PM
@Arden2 if you login to My Account using Incognito mode, is it showing Active?
Check Payment page and confirm if PM took the money and used it to process a renewal
If all good, try to reseat the sim card (power off, take sim out for a minute, then put it back and power up)
if still not working, can you tell us what is showing on the phone status screen? SIM not provisioned? No SIM? No network?
and you have another phone to test your PM sim card?
did you ever try to test the service in another area?
02-10-2023 01:20 PM
02-10-2023 01:18 PM
@Arden2 - when logged into your My Account (or when you dial 611, or # 1-855-478-2542 or # 1-855-4PUBLIC form another line) is your account status ACTIVE?
02-10-2023 01:18 PM
Auto pay can fail
To make payment and reactivate plan .. if you know PIN number you can *611 with a voucher and *611 no PIN needed . You can also do this by by calling 18554PUBLIC . otherwise log into self serve make manual payment and reactivate service and or update credit card if necessary
My account
Legend and features
Change plan / update cc /auto pay
Account #/ change # port /swap SIM
If you still have service and your plan renews today / tomorrow you can ignore this suspended notice
