02-25-2023 10:11 PM
Hi. I’m not sure if my phone got locked or not but on my SIM card it says locked sim. It is asking for a PUK number. Please help!!
Phones
02-26-2023 04:46 PM
Hi @Gurleen211 we are just customers and we cannot help
Check your Community inbox for their reply. If nothing there, message them again
02-26-2023 04:45 PM
Yes I have but I did not hear anything back yet.
02-26-2023 04:44 PM
Yes I have but I did not hear anything back yet. Please try to help me out.
02-26-2023 04:43 PM
hi @Gurleen211 if it is a sim pin you don't know, open ticket with CS agent for the sim pin PUK
02-26-2023 04:41 PM
She told me that there was a passcode where the sim is. Like the sim pin
02-26-2023 04:37 PM
Hi @Gurleen211 did you open ticket with CS agent ?
02-26-2023 04:36 PM
Hello. I have my SIM card in the same phone. There were no changes made like transferring
02-25-2023 10:44 PM - edited 02-25-2023 10:44 PM
Looks like your sister may have place a SIM lock on your phone.
Does she remember accidentally entered the SIM lock?
02-25-2023 10:26 PM
hi @Gurleen211 do you have another phone or your old phone to test the sim card?
02-25-2023 10:24 PM
@Gurleen211 look like it is a sim card PUK. please open ticket with PM support using the direct link
https://urlshortner.tiia.ai/Oyn1L6
02-25-2023 10:22 PM
I’m not sure what happened because my sister had my phone prior but when I revived it it says contact your provider your puk code
02-25-2023 10:21 PM
Hi @Gurleen211 if you phone was never used on Public Mobile, very likley it is a carrier lock and you need to ask your previous carrier for an unlock code
If this phone was used on PM before, then check your sim card on another phone, if you got the same error, then it is a sim card lock. Please open ticket with PM Support for the sim card PUK then
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
02-25-2023 10:17 PM
is it a recently acquired 2nd hand phone ? Perhaps it's been reported as stolen and blacklisted.
02-25-2023 10:15 PM
@Gurleen211 Before you open ticket with PM , can you confirm what was the exact error message? Depends on the message, you have to ask the PUK code from different places
If it is a Samsung and if the message is "SIM network PIN blocked. Enter SIM network PUK." ,
call Samsung 1-800-726-7864, The only info you will need to provide for a master unlock was the IMEI and where the phone was purchased
If the message is “PIN unlock key (PUK)” or "Enter PUK Your SIM cannot be accessed" or on an iPhone's status bar showing "Locked SIM"
open a ticket with PM Support using this direct link: https://urlshortner.tiia.ai/Oyn1L6
If the message is "SIM network unlock PIN" or "SIM ME lock code NP" or on an iPhone's About->Carrier Lock showing "SIM locked"
You have to ask the carrier where you got the phone from for the carrier unlock code. (PM would not be able to help with this)
02-25-2023 10:13 PM
