PUK locked out
buff5799
Telling me I need to get a moderator to give me access. I was locked out despite using the PIN number, can can someone please provide me with one.
8 REPLIES 8
@buff5799
Did you just purchased the iPhone 6?
If the SIM worked in your iPad, It sounds like the phone is locked. If this is the case, it will need the carrier that locked the phone to unlock it.
Hi @buff5799
to open ticket with Pm CS agent:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
  1. start by typing : Contact CS Agent
  2. then Click "Contact Us"
  3. then Click "Other"
  4. finally Click "Click here to submit a ticket"
@buff5799
ticket issue send by CS_Agent
buff5799
I can’t even create a ticket as it is giving me an error when I hit submit. I am using the SIM card number and the pin I created when I activated the account.
buff5799
It was an iPad Air initially but now it is in a iPhone 6 and the sim is locked. Asking for a PUK number.
RossN
@buff5799 hi if you locked your phone
 ask a cs agent tunlock it for you
contact a customer service agent
1.  you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
Yummy
Most likely you PIN code is entered incorrectly multiple times and hence locked (except for emergency calls) and requires a PUK (Personal Unlock Key) to reactivate it.
You will need to open a ticket with PM and their Customer Support could assist:
To contact CSA-agent, there are 2 methods:
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking Here
Find your PUK: https://www.publicmobile.ca/en/on/get-help/articles/where-to-find-your-puk
- SIM network PIN blocked. Enter SIM network PUK - is asking for the phone’s (often Samsung) “master code" after entering the wrong code too many times. Samsung and/or your previous carrier can give you this.
- SIM network unlock PIN" is asking for your previous carrier's unlock code - just contact them with your IMEI (dial *#06# to get it) and they'll give it to you. If you enter this incorrectly too many times, you'll get the error message above.
- PIN unlock key (PUK) is a SIM-specific code used to prevent unauthorised use of a SIM card.
The PIN (Personal Identification Number) enables secure access to the SIM card and network. It is provided with your SIM card.
    If the PIN code is entered incorrectly 3 times, the phone is locked (except for emergency calls) and requires a PUK (Personal Unlock Key) to reactivate it.
    Once the PUK is recovered and validated, you will be asked to choose a new PIN.
    Only Public Mobile's Customer Support Agents (CSA) can give you this type of code, which the device manufacturer cannot.
    Caution! If the PUK is entered incorrectly 10 times in a row, the SIM card becomes unusable.
dust2dust
What is the exact message your phone is giving you? Some are different needs. Did you ever set up the sim security on the phone where you have to enter a code to use the phone from a restart?
