PUK Number
Audrey6
Need PUK number
2 REPLIES 2
@Audrey6   there are different kind of PUK number,
What was the exact message ? is that SIM card PUK?
SIM card PUK is needed if you have setup your SIM with a passcode and you failed to enter it correctly multiple times and triggered the lock. If the SIM card PUK is what you need, you can open a ticket with PM Support using this directly link:      https://urlshortner.tiia.ai/Oyn1L6
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
If it is other kind of PUK, please provide the exact error and we can advise.
For example, "SIM network unlock PIN" is something you need to get from the carrier you originally bought the phone from.
"SIM network PIN blocked. Enter SIM network PUK." is asking for the phone’s (often Samsung) “master code" after entering the wrong code too many times. Samsung and/or your previous carrier can give you this.
