2 hours ago
Not a question but more of a PSA that if you're a low data user check your subscription to see if your account shows the $23-6GB subscription as an option. I am on the $25/5GB 3G plan that I accepted via SMS last year and even though $23/6GB shows on the public site as for new users only, it's an option for me to pay less and get more capacity. Sounds like this is YMMV, but take a look, it might be there for you if the subscription fits your usage.
2 hours ago
hi @pmva
yes, everyone will get different offers now. Usually higher priced plans. But those on top plans (like $50) will get options for $35 or so too
2 hours ago - last edited 2 hours ago
@pmva hi yes, you are correct. Some clients do have this in their existing account based on their current plan.
My $15 plan has $23/6, $19/1 and $20/3.
My $29 plan only has $34 and higher. It's all strategic planning.
