3 hours ago
My husband cannot login to his PM account after porting his number from another provider. The system is sending verification code to a temporary number he was requested to setup before request for porting. He tried to reach for help but could not figure out how to create a ticket. Is there a way for him to create a ticket without being logged in?
an hour ago
After getting request for a code he clicked "did not receive a code" which provided other options including email. Thanks for your suggestion. It would be more intuitive if other options were labeled directly.
3 hours ago
He should get the text if his old SIM is in his phone. The old SIM will work for 45 minutes to 2 hours and when the phone is on SOS. It is time to switch to the PM SIM.
3 hours ago
HI @Mirka1
check if email is an option to get the 2FA. click Resend code and check if send email there
if he can get the code via email, he can then go to Profile page, Manage EverSafe id and update to the correct phone number
if he still cannot login , then ask PM support agent to update it on behalf. Message support here
3 hours ago
@Mirka1 He can use this direct link to contact support to help
