05-25-2024
02:32 AM
05-25-2024
11:52 AM
computergeek541
06-16-2024 01:41 AM
@RayZ , I'm glad you were able to work it out with them. 🤗
06-15-2024 01:12 AM
@Sansan You're accurately right. They said I could choose either going back to the original plan where the 240GB were rewarding with then they'll at once pull back those 240GB towards me, or staying still on the 15$ plan, they could make up 5GB for me. I picked up the latter. How wise you were about this coming results!
05-29-2024 02:58 PM
Thank you! I tried to type in every words and it worked.
05-29-2024 01:05 PM
This could occur because you cut and paste something.
Try giving a brief description of your issue then give a full details when an agent replies back.
05-29-2024 12:54 PM
Message could NOT be sent as an error occurred. See heading on the pic. Tried different ways but always it's still...Can anyone help? Thx
05-25-2024 11:48 AM
@RayZ wrote:First of all, thank you for your reasonable answer!
Yes, I did just downgrade my plan. What I wanna clarify is, as long as the plan would be upgraded to a higher level, even though it's not the same as before, the bonus data will be back itself to my account, or I have to make it as before or higher, or I have got to request from somewhere or someone in PM afterwards?
Your 150 Day Bonus data has been forfeited and is gone...there's no way to get it back now, even if you change back to your previous regular plan. PM isn't gonna give it back to you now no matter who you request it from.
clipped from Help Files...
Will I lose my special bonus data if I switch plans?
The bonus data will remain active unless your account becomes inactive, you switch to a plan of lower value or to an incompatible plan.
05-25-2024 11:17 AM
@RayZ do not immediately change your plan again in hopes of getting the data back!
Once you downgraded the plan it is taken away and will not be added back.
Asking PM as stated in below message, is just a request which they can deny. Regrettably they are not obligated to give back, even though you didn't know that by doing the change you would lose the data given.
From my understanding, they will deny you or give you equal to the plan you changed to now. So if you changed to $15 plan, they will give you 5GB.
But use the link previously provided to ask and let us know the results if you don't mind.
Good luck.
05-25-2024 10:42 AM
05-25-2024 03:36 AM - edited 05-25-2024 03:37 AM
After you received the text, the bonus data will be added into your account but if you downgrade your plan...the bonus data will be removed. If you upgrade your plan, it will stay in your account.
If you didn't downgrade your plan, just contact a CS_Agent to investigate the issue. DM them at:
