4 hours ago
- last edited
4 hours ago
computergeek541
I have been given this Loyalty Bonus reward:240GB
4 hours ago
Yes, you can, but it will drain your battery fast, it could affect the battery life.
4 hours ago
Yes, you can use hotspot.
4 hours ago
So I can use up the data using my number as a hotspot feature?
4 hours ago
4 hours ago - last edited 4 hours ago
The bonus 240gb will kick in when you use up your monthly data plan…so stream away.
4 hours ago
nothing can be done, you can’t select which data add-on you can use
The system use Data is used based on expiry data, so first plan data, second loyalty 240GB data, last any other non expiry data
