4 hours ago
I just subscribed to the 50 gig Can/US data package. It said something about an ESim in the description. Do I need to do anything before I use the data in the US?
3 hours ago - last edited 3 hours ago
@RP72 wrote:I just subscribed to the 50 gig Can/US data package. It said something about an ESim in the description. Do I need to do anything before I use the data in the US?
In the cellphone settings...make sure to enable Data Roaming. When in US, make sure you're connected to either AT&T or T-Mobile...no others will work.
added...
as long as you were successful in activating your new PM acct...it will work with either hard sim or esim, whichever you activated with.
4 hours ago
Data roaming needs to be turned on to use data while in the US, and sometimes, customers need to manually select the correct network to connect to.
