10-07-2023 12:52 PM
10-07-2023 03:23 PM
CONTACT CUSTOMER SUPPORT
To contact a Customer Support Agent, send a private message to the Customer Support Agents by clicking here
You’ll need to be logged into your Community account for the link to work.
10-07-2023 03:17 PM
hi @CITRON
404 error because Chatbot is not the reliable way to ope n ticket. Please submit ticket with CS agent here
10-07-2023 03:11 PM
404 error
10-07-2023 03:06 PM - edited 10-07-2023 03:15 PM
hi @JayjayG
you copied from some smart guy, good start point. But since it is a word by word paste, better to provide reference.
AND FYI the Chatbot way is outdated
10-07-2023 03:01 PM
there payment systems are down also 3rd times 3 strikes your out
10-07-2023 02:58 PM
yes
10-07-2023 02:58 PM
Yes 404 errors
10-07-2023 01:04 PM
Are you on AutoPay?
I’ve been with PM for 2 years with AutoPay and never had an issue…knock on wood!
10-07-2023 12:58 PM
Hi. Have you tried using the different options in Payment to make a manual payment?
I think it is probably faster to open ticket with CS Agent and have them check, maybe a Fraud lock there for too many failed attempts
To open ticket with PM , at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
10-07-2023 12:57 PM
@CITRON , did you have auto subscription enabled on your account?
10-07-2023 12:57 PM
what makes you say that ? Dial 611 from your cell to hear current plan status. You can also pay by dialing 611 using your registered credit card...you will need to know your PM pin number.
10-07-2023 12:55 PM
Can you provide some additional information so that we can help you find a solution? Thanks
