4g Phone work on 5g plan?
Mikenet420
Can i use my 4g phone with a 5g plan? I know i'd only get 4g speed until i upgrade my phone. But i;d like to confirm i wouldn't have any issues having it work.
Mikenet420
Thanks for the quick responses. Big help. 🙂
hi @Mikenet420
yes you can.  You will have better speed than the max speed of 100Mbps with the 4G plans
Dunkman
Yes, your 4G phone will work with 5G plan.  You also may be able to get 5G speeds (250 Mbps)  on the LTE network with the 5G plan.
https://productioncommunity.publicmobile.ca/t5/Get-Support/5g-speeds-on-4g-phone/td-p/1033979
