01-25-2026 04:05 PM
I just created an account with PM.
I supplied my old phone number which has been transferred from lucky mobile to public mobile.
For some reason the esim is not downloading to my phone, I have used esims before so know my phone is compatible. The QR code that was sent to my email does not work.
I am now on SOS only and cannot access my phone number.
I need help ASAP, why is there no phone number to contact
01-28-2026 03:22 PM
Hi @CSA_PM i have not received a private message
01-28-2026 03:06 PM
I am also on SoS for 3 days. I finally got a CS agent to respond after 2 days and followed directions. Used teh online app to purchase eSIM, used the mobile phone app to purchase eSIM. Have spent $20 on eSIM that was supposed to be free. I try submitting a ticket and it doesnt work. The chatbot just says contact a CS agent. Please share any instructions for how to get teh SoS removed and cell phone working again.
01-28-2026 11:41 AM
Hi
I sent you a private message. You can view and reply to it by accessing this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
01-27-2026 07:43 PM
Have you tried this troubleshooting link?
01-27-2026 07:32 PM
01-27-2026 07:24 PM
please can you help, i have been on SOS only for 3 days now.
I have been asking for help for those 3 days and have heard nothing.
the esim has not worked, i did everything as i was told and now am stuck without phone or data usage.
I need someone to issue a new esim and assist.
01-26-2026 02:04 PM
tried, after the email otp, they still want my phone otp. like a double security
01-26-2026 02:01 PM
I can and then after I put in the email code it asks to send a code to my phone number
01-26-2026 01:58 PM
I have the same issue, but it needs two code verify and still need my phone otp code which doesnt have service to receive.
01-26-2026 01:52 PM
Check if you can get the otp code using email instead
01-26-2026 01:50 PM
Yesterday I signed up for public mobile.
I followed all instructions however i now have no service and am stuck on SOS only. it seems as the esim has not worked properly.
I submitted a ticket yesterday however now cannot login to my account as it is trying to send a code to my phone number which i do not have access on as I'm on sos only.
I now want to move to a new phone provider because this is horrible and there is no way to get any help. however i need access to my phone number to change to a new provider i am stuck and lost.
this is the worst phone company in the world!
01-25-2026 05:23 PM
As my plan is not working will i receive a refund as i am going to have to go with a different provider
01-25-2026 04:59 PM
Same situation, and they never reply to my DM
01-25-2026 04:31 PM
I have already submitted a ticked but have no received any help what so ever.
01-25-2026 04:30 PM
you check what suggested above?
to have PM to help, please submit ticket using direct message link i posted above
01-25-2026 04:29 PM
do you have a phone number to speak to an agent
01-25-2026 04:06 PM
the app should have installed the esim for you already, check if you see it there. Enable it and set it as Primary if it is there (and remember to remove old sim , disable old provider esim)
but if it is not there, then you will need to ask PM. Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
