11-06-2018 02:53 PM - edited 01-05-2022 02:24 AM
I understand that when you call the US - it will go through - My question is:
What if you are in the US - will your calls go through? and at that time - will you only need US data plans? OR how does that work?
11-06-2018 03:09 PM
@KMG wrote:@srlawren wrote:...except receiving incoming texts--those will get to you in the USA even without any roaming add-ons.
Is that only everyone with a text plan? Or only those with a Canada/USA calling plan?
@KMG everyone with a texting plan
11-06-2018 03:03 PM - edited 11-06-2018 03:03 PM
11-06-2018 03:01 PM
@KMG wrote:The Canada/USA calling plan only applies when you are calling while you are in Canada.
If you travel to the US, you would need to buy US add-ons in order to do anything.
11-06-2018 02:55 PM - edited 11-06-2018 02:56 PM
