PLAN - 90 DAYS - DATA 12GB
08-26-2017 01:29 PM - edited 01-04-2022 02:34 PM
08-26-2017 04:54 PM
if you recently got this plan, it takes a couple days for the 6gb to change to 12 gb.
08-26-2017 02:10 PM
thanks! I will
08-26-2017 02:06 PM
Hey @Willard - you're going to have to send a private message to the mods to help you with this. Be sure to include your PM account number, phone number, and the email address you use to log into self-serve in the message.
Click Here to send the mods a direct message.
Good luck!
