PIN number
rocky5
How do I find my 4 digit pi
HI @rocky5   If you have forgotten your PIN or unable to find the PIN back form the text as advised by @computergeek541 , the only way is to contact PM CS agent to reset it
To do so, Click on the Bubble or directly at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
  1. type: Forgot log in information
  2. Click "Contact Us"
  3. Click "Click here to submit a ticket"
  4. you will then direct to another page to open ticket.
If you have problems submitting a ticket, you can also send a private message to the moderators (but this can take longer):
Did you activate online or in-store?  In either case, you would have received a text message with the account PIN.  I would check your device to see if it's still saved there.  Also, if you performed an online activation, the account PIN would be whatever you chose at the time.
@rocky5
Which PIN?
- security PIN?
- SIM PIN?
- Samsung phone PIN?
