02-27-2022 07:48 PM
Need to reactivate so I can change credit card info. Unfortunately missed my monthly plan
02-27-2022 08:12 PM - edited 02-27-2022 08:14 PM
Here's where you can get them, @Zeus . You can also get them online at Public Mobile online top - there is likely a small fee for this service.
02-27-2022 08:10 PM
@Zeus : recharge.com seems good. Seems to work _almost_ immediately. There's a slight surcharge over buying in a store. And that's also dependent on what province you're in.
02-27-2022 08:03 PM
Yeah I'm just buying vouchers online now... Looking for them i should say lol
02-27-2022 08:02 PM
It's Disabled
02-27-2022 07:58 PM - edited 02-27-2022 07:59 PM
@Spudster : Excellent...for when he's logged in. 🙂
@Zeus : Give it another hour and try again. Use the Forgot your password? link then. You can only make so many attempts before it thinks you're trying to break in.
Edit: Oh, and to get your services working sooner you could buy vouchers in many stores or online and redeem in the 611 service. Or use the instant top-up method in a few stores. Then figure out your login and changing card.
02-27-2022 07:53 PM - edited 02-27-2022 07:54 PM
You can make a manual payment using a payment card to reactivate service.
Then, before logging into your self-serve account to update credit card, recommend following this procedure to avoid the common glitches that sometimes occur with this process:
