PDF Invoice Of Usage history
karuna_w97
Hallo,
May I please request a PDF Invoice of my usage history, to see my Bill statement for the past 3 month period.
Please and thank you.
Regards,
KW
@karuna_w97
Depending on the details of the bill statement you are looking for. You can login to your account and click on View Payment History. Change drop-down menu from 7 days to 90 days and adjust the start of the billing date and finish of the billing date.
I hope this helps on what you are looking for.
Otherwise, as noted by others, contact a CS_Agent for a PDF billing invoice.
@karuna_w97 Please open ticket with PM support  for a PDF invoice.  it might take them 2 or 3 weeks to prepare
To open ticket:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
NDesai
@karuna_w97 To get that you will have to reach out to CS Agent.
Here’s when and how to contact our Customer Support Agents:
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work.
