10-12-2025
04:11 PM
10-12-2025
06:39 PM
computergeek541
Hi i have been charged for 2 plans via my bank account. Would like a refund from one of the payments as i only need one subscription plan for my phone. Ty
10-12-2025 04:18 PM - edited 10-12-2025 04:19 PM
@Hollywood28 If one charge is just pending and the other charge has posted , then the pending charge should fall off , however if both charges have posted and you didn’t change plans immediately instead of on renewal then please engage support to help fix for you
you can use the orange chat bubble bottom right of screen or send a private message To CS_Agent
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
10-12-2025 04:16 PM
PM has no refund policy. But if your second plan is just actived and not really been used, there is a chance they will be ok to issue refund
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble with open ticket using Chatbot, then message them using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
