Out of minutes? Thought calling was unlimited
09-09-2023 07:35 PM
09-09-2023 07:43 PM
@Ermina wrote:Unlimited calling only for incoming calls! Ask your friend to be the one calling first by texting them haha (also unlimited)
Only the $15 plan has limitations on outgoing calling minutes (100 mins) and all plans include unlimited incoming calls. If you have the $15 plan and are low on calling mins, consider getting the $5 / 500 minutes of Canada wide calling add-on. Good to have in case you run outta regular plan mins before next renewal.
09-09-2023 07:38 PM
09-09-2023 07:36 PM - edited 09-09-2023 07:37 PM
anything more than the $15 plan has unlimited calling to Canada from Canada. If you have more than $15 plan...just try re-dialing again....added ...and ignore that stoopid message.
