10-11-2023 01:10 PM
Hello!
I currently have a plan that is Canada-US unlimited talk and text. When I try to make a call to the US, it says I am out of minutes? Has anyone experienced this before?
10-11-2023 01:24 PM
@Rach_95 , check to make sure that your account is in active status.
10-11-2023 01:18 PM
Did you try to reboot your phone? (turn it off, wait a bit, turn it on).
Can you try to make a call using your SIM card in another phone?
10-11-2023 01:18 PM
are you sure you have the correct Canada / US calling plan ? Sounds like you had US calling add-on that had limited minutes and you've run outta mins. Just log in to confirm.
10-11-2023 01:15 PM
I tried that, I gave it 15 minutes to try again and it still giving me the same error message (that I am out of minutes).
10-11-2023 01:13 PM
sometimes this happens to me while calling a Cdn number from Canada. Just try disconnecting the call...then redial. If you can, wait for a few minutes, then try again.
