Lost Sim
10-11-2023 01:00 PM
Hi
I have lost my phone and want to replace my sim but want to keep the same number as I use it for my CRA login etc.
Can I get the same sim reissued to my address. Urgent help needed
Plans
10-11-2023 01:26 PM
get a replacement sim, then log in to your account and do this to change the sim number. You'll still have the same phone number as you had...
10-11-2023 01:15 PM
10-11-2023 01:11 PM
Definitely do not cancel the account or you will lose the number.
But you will want to mark as lost/stolen as I outlined earlier.
10-11-2023 01:09 PM
Once you change the SIM card number everything will be switched over to the new SIM.
Don’t cancel your subscription because you will need to pick a new number as your old number is linked to your old account.
10-11-2023 01:09 PM
Oh great. so I don't need to cancel my subscription or anything
10-11-2023 01:08 PM
@Rabiaz wrote:But I want the number to be same, will I be able to update the same number? will I need to cancel my subscription?
Your phone number won't be affected. When you have a new SIM card, go to your online account, under the profile tab you will see the current SIM number, just do a number update using the new SIM and you are good to go.
10-11-2023 01:07 PM - edited 10-11-2023 01:09 PM
first, go into your account and mark your device as lost/stolen.
Then acquire a new Public Mobile Sim card, then go into self-serve profile and update the Sim number associated with your account.
Then go back under the lost/stolen, designation and reverse what you did initially.
10-11-2023 01:07 PM
So just update my old number? will I need to cancel my subscription?
10-11-2023 01:06 PM
10-11-2023 01:05 PM - edited 10-11-2023 01:07 PM
You should pickup a new SIM from your local Telus/Koodo store then login to your account and go to the Profile section and click on Change SIM Card Number.
When login to your account click on Resend Code/Didn’t Receive Code and you will have the option to have the 2FA code sent by email.
10-11-2023 01:03 PM
@Rabiaz , please use incognito mode on your browser when updating the SIM card number. It should work.
