Out going calls
Nellena
Why can't I make out going calls as I have just made a payment with a voucher?
@Nellena ,
If you have no services:
  1. Add Funds to your Plan Amount (through SELF SERVE or by calling 611 if you have a card registered)...which it sounds like you did.
  2. Method through Self-Serve account: Go to “Plan and Add-Ons” > Lost/Stolen Phone
  3. Select Resume/Reactivate Service
  4. Reboot
All okay now?
 @Nellena : This isn't a pay as you go place. Adding money doesn't do anything unless suspended with nothing working.
Once added then you could buy add-ons, or change plans immediately or ask the moderators to renew early. Or leave it for your renewal.
If you're on the $15 plan then perhaps you're out of minutes.
If you're on the new provincial $15 plan then I've been reading a few reports of people not having unlimited incoming. That would need to be fixed by the moderators.
So you can use that money you deposited and buy the $5 calling add-on until you renew or things get fixed.
Triguy
Check your account status.  If you have limited minutes do they appear under data and add-ons.
Try rebooting your phone.
