03-12-2021 04:32 PM - edited 01-06-2022 02:17 AM
Hi there,
I have long distance calling to the states as an add-on with my plan but I cannot seem to contact the 605 area code in the states. I can connect with other area codes in the states, but not this one. Please advise.
Thanks,
Christ is King,
Colton
Service
03-12-2021 07:07 PM
@ColtonErismann I use a long distance calling card for my calls to the USA. I find it's a bit cheaper, and they are pinless, you store it on your phone, it's easy to use. $10 lasts me about a year, rates are $0.011/minute. Here is a good link if you want to buy one online
https://www.phonecardsplus.ca/calling-cards.html
03-12-2021 04:37 PM
Some phone numbers are not accessible to the USA
Here is from the plans page
Calls made to numbers starting with the following six digit combinations are not included in US calling from Canada and will not be completed when dialled: 712-432, 605-562, 641-552, 605-475, 605-477, 712-775, 559-726.
