08-12-2021 02:30 PM - edited 01-06-2022 03:09 AM
When i dial a call it tells me I've used up all my minutes but I have unlimited calls so wtf? How do I get this fixed when theres no people to talk too?
08-12-2021 06:02 PM
Oh come on we're all grown-ups here. And the kids have heard it all anyway. And the kiddie kids aren't reading this anyway 🙂
08-12-2021 05:36 PM
@Meow I love these!!! 1 & 6
08-12-2021 05:32 PM
@jimmiedmc85 wrote:When i dial a call it tells me I've used up all my minutes but I have unlimited calls so wtf? How do I get this fixed when theres no people to talk too?
Most issues are easy to fix.
1. Do not swear
2. Search forum for similar issue(s). Read resolution suggestion. Try them...
3. Ask question in Community
4. Wait few minutes and somebody will suggest resolution
5. If advise did not resolve your issue, wait few more minutes and you will definitely get few other advises.
6. Do not curse...
08-12-2021 03:01 PM - edited 08-12-2021 03:04 PM
This would be considered a minor provisioning issue which means you should be able to solve it yourself. Run thru this list of troubleshooting tips testing after each one til you can make a call out.
* Skip for your issue.
**Caution an effective method but your rewards will not apply upon renewal and you will have to contact customer support and ask them to apply your rewards manually to your account.
08-12-2021 02:51 PM
@jimmiedmc85 this has been a common issue last two days
Please try reboot your phone
or add 1 in front of the number you are calling eg. 1-519-123-4567
08-12-2021 02:34 PM
To get the obvious out of the way...you used ( +1 or 1 ) in front of the country code,
Sometimes there are some extra leading zero's in country codes and "foreign" area codes.
Maybe try not using leading zeros.
Make sure your phone is off before removing and reinserting its SIM card.
do one thing rebooting your phone take your SIM card out and waiting for a 2 minute and put it back and turn on -This one is quick and simple.
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
and at public mobile you can't talk to Customer Support Agent, you Have To Submit a Ticket To Customer Support Agent by CS_Agent,
Only one way to solve your issue , explanation to Customer Support Agent by CS_Agent,
and the are nice service Team the will help you 100%.
Here’s how to contact Customer Support Agent by CS_Agent,
Good Luck
08-12-2021 02:33 PM
That has happened to me a few times a few months ago.
A reboot seemed to reset things.
Also, do a Reset of your Network Settings.
I never had to contact the Public Mobile CSA's about it, it seems to diminish and resolve itself on it's own.
But if adding a '1' does not help complete the call and you continue to get this message without calls completing, I would inquire with CSA.
Two methods to reach them here:
https://www.publicmobile.ca/en/on/get-help/articles/contact-a-moderator
08-12-2021 02:31 PM
Try rebooting your phone. Also try dialing 1 + area code.
