Oppo F1s or A1601
11-24-2019 05:13 PM - edited 01-05-2022 08:07 AM
Is this device will work with public mobile? I check the compatibility and not quite sure with the answer. If someone is using with the same device and working please let me know. Thanks
Phones
03-15-2020 02:17 AM
My daughter doesn't have issue with here phone. A guy from the store configured everything.
03-15-2020 12:06 AM
Yes that worked! I had it on default before! Thank you so much!
03-14-2020 11:34 PM
@syd1 wrote:Hi,
I have the same phone and it works on my phone. I only have an issue that I cannot receive or send mms messages. Other than that, everything else works. Hoping to figure out the mms situation soon though!
Syd
Have you tried adding ,mms into the APN Type field in your APN settings?
03-14-2020 11:24 PM
Hi,
Syd
11-24-2019 06:09 PM - edited 11-24-2019 06:09 PM
Unless it is an Oppo product manufactured in 2014 prior to their exit from the North American market, avoid that brand because of the lack of compatibility with North American bands. Try the OnePlus brand. These two brands are sibblings. The parent company is BBK.
11-24-2019 05:49 PM
I think @computergeek541 has already answered it correctly.
If you buy a phone that only supports B5 (850) for 3G, and doesn't support B2 (1900), you are at risk of having no voice calls in many locations.
11-24-2019 05:38 PM
@Rj3k if it says that then it should work!
11-24-2019 05:37 PM
I used https://willmyphonework.net/ and says supported 3G and 4GE LTE Network. Is this good?
11-24-2019 05:31 PM
Thanks!
11-24-2019 05:31 PM
Thanks looks like will not work then.
11-24-2019 05:30 PM
Yeah it was purchased long time ago and we want to switch to public mobile. But if doesn't work then that's fine.
11-24-2019 05:24 PM
@Rj3k wrote:Is this device will work with public mobile? I check the compatibility and not quite sure with the answer. If someone is using with the same device and working please let me know. Thanks
@Rj3k not good choices. If you want a Chinese phone that covers most of the NA bands look at Umidigi F2.
11-24-2019 05:19 PM
This phone has the following specs:
https://www.gsmarena.com/oppo_f1s-8239.php
It missing 3G - 1900 band. It does have several of the 4G bands.
3G bands | HSDPA 850 / 900 / 2100 |
4G bands | LTE band 1(2100), 3(1800), 5(850), 7(2600), 8(900), 20(800), 28(700), 38(2600), 39(1900), 40(2300), 41(2500) - Global |
LTE band 1(2100), 3(1800), 5(850), 40(2300) - India |
Public Mobile uses the following frequency bands:
- 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
- HSPA: 850 MHz, 1900 MHz (UMTS).
11-24-2019 05:19 PM - edited 11-24-2019 05:19 PM
The F1s should not be purcahsed for use with Public Mobile. It lacks WCDMA band 2.
https://www.oppo.com/en/smartphone-f1s/#specsgroup1
11-24-2019 05:17 PM
@Rj3k can you check it on willmyphonework.net
