04-23-2025
01:42 AM
04-23-2025
06:33 AM
computergeek541
Hi I'm from China, using a phone called OPPO FIND X8, the IMEI is IMEI1: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Where can I check if my phone can use the sim card? Or if it can't be used, can I get a refund if the sim card is delivered already?
04-23-2025 09:35 AM
04-23-2025 04:35 AM
Thanks but I don't know how to remove it...
04-23-2025 04:11 AM - edited 04-23-2025 04:28 AM
Please remove your IMEI from this public community forum so click on V in circle and edit out.
Your Oppo Find X8 will either have Nano SIM/eSIM or Nano SIM/Nano SIM. You can check to see if there is a dual SIM tray in the phone.
https://m.gsmarena.com/oppo_find_x8-ampp-13407.php
You can go to the settings and check for Add eSIM if it is eSIM compatible.
