4 weeks ago
3 weeks ago
Update: Public Mobile had Telus call me, who verified my phone is incompatible with the network changes and the reason why it sometimes works and other times not is because it depends on which cell phone tower I'm connecting to, as they're not all upgraded at the same time. I need to switch service providers, so now back to PM to see how they respond given the extreme inconvenience and loss of service for which I've been paying for.
4 weeks ago
I tried 2 of my phones, I got the 2 green checkmarks for both phones:
"Your phone is compatible.
4 weeks ago
Try testing your phones with the Telus VoLTE compatibility tool in this link and let us know if this tool confirms whether your phones are no longer compatible. Good luck.
4 weeks ago
Right, I suppose that's where it might help if they explain why your phone is incompatible. Perhaps the bright side is that most/all other service providers have real people you can easily connect with to determine what you need to.
It'd be nice if they didn't try to fix things that aren't broken, or at least inform folks before they make such a change to a critical service that some people heavily rely on.
4 weeks ago
Who knows if the new provider won't have the same issue or even if it works it might change in a few months.
4 weeks ago
Is it not an option to consider a different service provider that your phone would be compatible with?
4 weeks ago
I have a Motorola G phone that I bought 5 years, apparently not compatible anymore as of this week.
I'm in Montreal. They didn't present any options, they only said my phone is not compatible.
I don't have any other options, so I'm on the search for a new phone.
4 weeks ago
Where are you and what type of phone do you have?
Did they present options to you?
What are you doing as a result?
4 weeks ago
I am having the same issue. I can receive calls, but usually I cannot make calls (this happened this week). I sent a PM to a support agent and they escalated my issue and someone from Public Mobile/Telus called me and said my phone isn't compatible.
4 weeks ago
Thanks for letting me know!
Any idea why I can sometimes make calls and other times not?
Very surprising and sad that Public Mobile would make such a change without informing us whatsoever. Might you know if it's possible to keep it the way it was and avoid trying to fix a problem that doesn't exist? If not, does this mean that I've got to switch providers?
4 weeks ago
@Hipdiver1 wrote:I have a Samsung S10+, bought in Canada. How do I find out if my specific phone impacts its ability to make calls?
The Samsung Galaxay S10+ cannot use VoLTE at Public Mobile.
4 weeks ago
I am not in any of these areas you mention. I'm in NS. Does this mean my phone should not be affected? If that's the case, I'm still at an absolute loss as to why I periodically can't make calls.
Very confusing to me that it will sometimes make calls and other times not. Appears this has nothing to do with service/connection, as I've had this issue at home, where I've never had it until very recently.
Any other suggestions/assistance would be much appreciated, including how I can connect with a real person at Public Mobile.
Thanks so very much!
4 weeks ago
HI @Hipdiver1
what phone do you have?
Not sure if that impact your voice calls
Telus is refarming all of their 850 to 10 MHz LTE B5 in their markets, mainly BC, AB, Windsor, Ottawa, GTA area Montreal, Quebec City. Bell has not done this, so it won't affect area that has Bell networks which Telus/PM use
So, if your phone has only 850 Band 5 on the phone but lacks 1900 Mhz, if your phone were bought from another country, or an imported model, then you might be impacted
On the other hand, if the phone has 1900 Mhz, or it is a Canadian/US model, it likely won't be impacted and won't see service degraded
https://www.publicmobile.ca/en/get-help/articles/850-turndown
