11-24-2016 03:11 PM - edited 01-05-2022 12:55 AM
Hello,
I don't know which mod to best reach out to (hi all :D) or if I should add to a related thread,
but with my service, I get data and can call, but my number is unavailable when people call me.
Thank you.★*☆
12-07-2016 12:39 AM
Whew yay, I'm fully on. (◕‿◕)
I got a reply from my Facebook message the other day after activating my old sim back on the old network, the pm crew officially ported my number over.
I get phone calls now
Thaaanks.
11-24-2016 03:46 PM
Sounds like a port issue @tactfulcoconut
I would suggest message again though
Your first message sounds more like you just verify port info
So mod may not realize severity of issue (no incoming calls is essentially a service issue, so make sure to mention service disruption, the mods have been trying to fix these first before checking all other issues)
11-24-2016 03:32 PM
Okay great thanks,
I had messaged a mod to check if my port went through successfully a couple days ago and included my SIM number and the EMI, MEID stuff.
I'll just be waiting through the queue : D
11-24-2016 03:21 PM
Contact a mod as per the post above. put your old sim in and see if that works. if it does use that until PM ports your number
11-24-2016 03:13 PM - edited 11-24-2016 03:14 PM
@tactfulcoconut Can you provide some more info? Did you try to port a number start a new one?
As far as contrcting mods, it doesnt matter which one you send to they all read each others messages. Be sure you send them a private message with all the important info from the below post.
11-24-2016 03:13 PM
You need to send a moderator a personal message. This is the process you should follow!
