06-26-2023
03:13 PM
06-26-2023
06:07 PM
computergeek541
I have one contact in my phone who, up until about 3 weeks ago, was receiving my texts just fine. Seemingly out of the blue he stopped receiving my texts. I can still receive his but anything I send him doesn't come through and if I call him it rings on my end but not his. He also won't receive the voicemails I leave. He has contacted his carrier, changed carriers, and we have both done everything we can think of to remedy the situation (neither of us are blocked, we've blocked and unblocked each other just in case, deleted and reinstalled apps, cleared caches, ect) Anyone have any idea what's going on? Seems to be just an issue between him and I.
06-26-2023 07:26 PM
@xtina90 glad it helps!!
what was done was that by putting your sim in another phone, it forces a sim card reprovision on the system. That helped to reset the account on the backend. Cheers
06-26-2023 07:20 PM
Switched my SIM to my boyfriends phone and texted the specific contact just fine. Put my SIM back into my phone and now I can text that contact again. Thanks for the input, turns out I just needed to take out my SIM and put it back in.
06-26-2023 03:28 PM
The blocked idea suggests another thought. Can you turn on the hide your number feature and then try calling. Unless he has that option of blocking all unknown callers turned on.
06-26-2023 03:25 PM
Maybe your friend accidentally added you to a blocked list... have them double check that option in their contacts.
06-26-2023 03:24 PM
@xtina90 he changed carrier for you for this issue?? You two must be buddies
you really meant you call him and your end rings???
I think it helps to try a different phones on both your friend and yours. Get a phone from another friend, you put your sim in the test phone and he put his in his test phone and see if it helps. This is to rule out any chance of a device issue on either end
06-26-2023 03:16 PM
Are you using his contact to contact? Try straight dialing. Maybe delete him as a contact and straight dial.
