One plus phone
L_D
Since switching to public mobile my one plus phone is not able to send or receive picture texts.
Phil_Adelphus
@L_D   As well as changing the APN settings as mentioned, some people with OnePlus phones have found it still didn't work until they put the SP.MB.COM in all caps.
@L_D wrote:
Oneplus 8T 5G
MMS texts should work. Upgrade phone operating system? Need to troubleshoot your APN settings.
Looks like some customers toggled airplane mode on, then off.
L_D
Oneplus 8T 5G
Dunkman
@L_D
Which model of one plus?
With some older phones, issues with MMS/picture messaging:
https://productioncommunity.publicmobile.ca/t5/Announcements/Picture-and-Group-Messaging-End-Date-Fe...
Might want to reboot your phone.  Network reset of phone (this will erase any saved Wifi passwords)
You can also check your APN settings:
New Settings:
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
APN Type: default,supl,mms
                             or             default,mms,agps,supl,fota,hipri
Chalupa_Batman
Hello @L_D
https://www.publicmobile.ca/en/on/get-help/articles/volte
Check to see if your phone is compatible with Public Mobile.
Something you can try is to go into your network settings and turn off automatic and choose Public Mobile and reboot. That helped a buddy of mine.
