Partial port
gafoor
I ported my phone from Rogers and opted  for public esim. I removed Rogers sim after confirming yes to the porting sms.. Now I can see public network. I can make outbound calls and receive calls from certain numbers. All other calls are going to Rogers voice mail. I am also not getting any text messages. It has. been going on for the last 3 days with no change.
2 REPLIES 2
Paul215
You can also try calling the porting department. I don't know if it is open today, I'm sending you the number by private message.
Hollister
@gafoor
Sorry I see it has been 3 days ago. Your port might be stuck. Try messaging an agent using the chatbot.
If you have problems with the chatbot you can private message
