Activation failed
03-31-2024
11:09 AM
03-31-2024
04:18 PM
computergeek541
03-31-2024 12:52 PM
Thank you 🙂
03-31-2024 12:30 PM
03-31-2024 12:21 PM
the link is not active anymore... can I ask you to send it again?
03-31-2024 12:08 PM
use that 2nd link provided by hTideGnow to message Customer Support for their help.
03-31-2024 11:56 AM
03-31-2024 11:53 AM
I paid… transfer successful… then when installed PM add… filled out all questions, then tryed to transfer the number… hit “submit”… the next page said “Activation faild”
when I tried to restart the application it sent me to the same page…
03-31-2024 11:22 AM
@IrinaRo wrote:It is a physical sim
OK...so how far into it did you get ? Did you get to the part where you pay $$ yet ? Were you able to create a PM account ?
03-31-2024 11:21 AM
03-31-2024 11:19 AM
Yes
03-31-2024 11:18 AM
hi @IrinaRo did you get an activation failed error, eSIM or physical sim
you can try to logout and wait 5 mins and try login using the app again
if still fails, you will need agent to help, please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
03-31-2024 11:11 AM
you must use the free PM app to successfully activate your new PM account...did you use it ?
