03-25-2022 10:32 AM
Can I use a single email address to manage 2 accounts (2 phone lines)?
03-25-2022 01:05 PM
@damenace wrote:Thanks all! My question has been answered.
Hi - You can now credit a member with the "solution".
03-25-2022 12:48 PM
As noted by everyone here, 1 email/account.
You can also open a mailbox with Outlook or Shaw if you have a mailbox with Google.
03-25-2022 11:47 AM
03-25-2022 11:37 AM
@BorisDoris wrote:
@damenace wrote:Sorry, I don't understand. Let say my email address is peter@gmail.com
If your main email is peter@gmail.com then emails sent to
will end up in the same mailbox - peter@gmail.com but for PM all 5 emails will be considered as unique. So you can have 5 PM accounts (OK, 6 including peter@gmail.com) and all communication will end up in peter@gmail.com
That's great .... didn't realize one could just place dots instead of creating separate unique aliases.
03-25-2022 11:32 AM
An idea might be to use the last 4 digits of the phone number of the account. email+1234@gmail.com. Then another email+4321@gmail.com. Then they come to your one "email" inbox and you see the additional numbers and recognize that that email was being sent to that account.
03-25-2022 11:26 AM
HI @damenace you can try to use those alias suggested above. The email addresses look different but messages sending to all those would go to the same mailbox
However, if you decide to use alias to create new My Account as a workaround, please write it down and make sure you remember what pattern you used. Many people forgot and would be trouble to reset the password
03-25-2022 11:23 AM
03-25-2022 11:19 AM
Then use peter+1@gmail.com
03-25-2022 11:17 AM
03-25-2022 10:59 AM
I confirm alias work for gmail.com.
Add DOT '.' anywhere and it go same address!
PLUS '+' works too but dot more common.
03-25-2022 10:49 AM
Where did my post go????
PM requires one unique email address for each PM account.
But if you have gmail email you can use alias feature. For example if your primary email address is abcdef@gmail.com email sent to abc.def@gmail.com will end up in the same mailbox.
I believe abcdef and abc.def will be considered different email for PM.
03-25-2022 10:37 AM - edited 03-25-2022 10:41 AM
No you can't officially. But if you use google you can use an alias using the + or . Trick.
Name@gmail.com = name+123@gmail.com = na.me@gmail.com
Edit. This still is two seperate selfserve accounts but emails will all go to one inbox. Outlook offers a similar alias functionality but not sure details
