Old rewards program
miakol
I want to switch my current plan to the new 4GB 4G plan. If I am still on the old rewards program will I lose those rewards when I change my plan?
JL9
no it won't change, you lucky devil you lol, I wish I was able to ask that question and get the good news lol
miakol
Thanks everyone for your help!👍
Hi @miakol   You won't get force migration with plan change.  At least for now, you will only be on the new Rewards system if you opt-in yourself
Yummy
If you are on old rewards program you can switch to any Plan you want. Rewards will not change to Points UNLESS You change type of rewards. So be careful what you click on 😉
@miakol   No worry, changing plan won't change your reward
So, go ahead and make change to your plan, you will still be on the old rewards
Just a reminder, when you make plan change, there will be an option Change plan now and Change in the next renewal date.   Make sure you understand the difference.  People usually pick Change in the next renewal date if you do not need the extra speed now.
