Old reward program, plan change
Keeley
Hi,
I was wanting to change my current plan to one with more data, but I am concerned that if I change my plan I'll be changed from the old rewards program to the new one. Does anyone know if I can change my plan and stay in the old rewards program?
Thanks!
WolverineCaz
That's good to hear that it won't chage my rewards because I was curious too.
Keeley
JK8
@Keeley
Changing plans will not switch your rewards plan.
Outdoorsman
@Keeley no worries you can keep your old rewards program
Plan changes don't change your rewards system.
Quigley
@Keeley
Don't worry.
Changing plans won't change you over to the point rewards system.
