Old $35 account data amount
Lar1
Does anyone remember how much data was included in the old $35 plan and how much extra data for autopay? I know what shows on the account but for some reason I thought it was higher.  Total data shows 1.5GB available. Thanks in advance
@Lar1 wrote:
Softech, thank you for clearing that up.  Will look into changing to the $39 plan and hopefully stay on the old rewards program.
@Lar1
no worry, You can freely change plan and it wont' affect your current rewards, also confirmed by Community Manager here:
https://productioncommunity.publicmobile.ca/t5/Announcements/FAQ-amp-Troubleshooting/td-p/986594
Will I be moved to the new rewards program if I change my plan?
Changing your plan won’t automatically transfer you to our new Public Points rewards program. If you’re currently on our legacy rewards program, you will continue to stay on it. However, we encourage you to explore Public Points, as it opens up even more opportunities for savings.
Lar1
@Lar1
yes, at around 2018, there was the "ready-made $35 1.5 GB plan", or the $35 1GB plan was added with the bonus 500MB with Autopay
https://productioncommunity.publicmobile.ca/t5/Announcements/UPDATED-Get-500MB-AutoPay-bonus-data-on...
Plan details:
  •     30-day plan
  •     1 GB Data at 3G speed
  •     +Bonus 500 MB with AutoPay
  •     Unlimited Canada-wide Talk
  •     Unlimited International Text and Picture Messaging
  •     Voicemail and Call Display
PM has changed the $35 couple times after.  The first change to $35 plan was the upgrade to 2GB (2.5GB with Autopay) in Sept 2020
https://productioncommunity.publicmobile.ca/t5/Announcements/New-Plan-35-for-2GB/td-p/594412
But you have to manually change to the new $35 plan, the system won't automatically change it for you
There is no more $35 plan now.  You can get $39 plan for 20GB or   $25 for only 1GB if you don't want to spend more.  (Please note that the $39 plan is a limited time promotional plan, so PM can pull it off anytime.  But once you are in, you are in. So, get it quick if you like that plan)
Lar1
Online account says the plan has 1.5gb data and it's with autopay. I think there was a time when the plan could be updated at no cost to more data, something like from 2.5 to 3GB but that was not done.  Anyway the plan now shows just 1.5GB of data available per pay period.  Doesn't seem to be anyway to check what the original plan included
@Lar1 the old $35 plan was 3GB with Autopay.  For sometimes, the Autopay data bonus was given even without Autopay enabled
You still have that plan??
